New to the forum and Drone flying
Hi, I am new to the Forum I am from Houston, I am getting back into drones. I had a Spark but after seeing all of the requirements did not fly much, now the battery is dead. I am now have a Mini 4 Pro. And I am starting to try to figure it all out.
Welcome to the forum. We look forward to your participation and your view of the world.
Reactions: LoudThunder
As an "old" Drone Pilot, there may be a couple of Legal Things you still need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
adamsc57
