Newbie from Los Angeles, CA
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .
Thumbswayup
Hi SpiralForce Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Mini manual HERE
You want an SD card that is U3 for 4K
Most of all have FUN
Welcome to the forums - a lot of good info here. So, take a look around and hope you enjoy some of the fine photography and information posted by the members.
Also, if you haven't done so yet, consider getting the AirMap and KittyHawk apps. I also suggest this Visualize it: See FAA UAS Data on a Map
Welcome to the forum! :)
New Mavic Mini pilot. I'm still trying to learn the basics of piloting
Here are some things to help you get started with your Mavic Mini:
  • The current Mavic Mini manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Mini downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Mini manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
RobertCNewman
