Newbie in all things drone - New Zealand
From California, US - @Manicmedic - Thanks for joining us @ MP!
You'll need to to check with your country's Aviation Authority to see what the rules are for flying drones there. I'm sure they have flight rules, requirements for registration of the drone, etc. Enjoy flying - it is rewarding to see what your drone sees. Also, you can find video editors so you can edit and share the places you've flown.
Welcome From Bakersfield!!
On rainy days you can sit back and read thru the Forums You will learn a lot!
Welcome.
First thing, downlaod the control app Go4 from either
DJI GO 4 - Download Center - DJI
or if you have an android phone
DO NOT download it from anywhere else.
Play with it on a phone even if you are getting a drone with a smart controller
Download and read, MANY TIMES, the drone's manual
There is A LOT in there and I would bet you will miss stuff, or miss the significance of stuff, on the first few read through.
When you get the drone DO NOT rush out and try to fly it.
I suggest you compare the manual with the working Go4 app when connected to a live drone.
Direct the output of a fan over the drone to help keep it cool.
DO NOT bother about updates at the moment and decline any that are offered.
Check that the following options are set
Beginner mode ---------- is set to off
"RTH at Current Altitude" is set to off that's a debateable one
In "Adavanced Settings"
"Emergency motor stop" is set to "Breakdown" AND NOT "Always"
"RC Signal Lost " ---------- is set to "Return to Home" = RTH
Personally I would switch OA, obstacle avoidance, OFF.
It nearly cost me my m2p on its first flight, or rather, my not knowing it was on and what it would do, nearly cost me the drone.
Hi,
I'll be collecting my 'new to me' Mavic 2 Pro in a few weeks. A good deal. It's worth the older drone, and if I enjoy it, then maybe when the Mavic 4 arrives, I'll swap once I have some basic skills.
Lovely but very wet at the moment Whangarei, New Zealand.
Good choice for a first drone. Proper workhorse with more features than you can shake a stick at. Welcome from the UK Midlands.
M Pro 2 caution:
Never use a battery that has the slightest hint of swelling. The M2’s early batteries were notorious for swelling and popping out of the drone while flying. Even with good batteries (replaced all mine at least twice), I use a velcro strap around the battery, in case it swells, it won’t eject from the drone.
All (?), newer DJI products enclose the battery within the drone. 😊
Reactions: LoudThunder
Since you live in New Zealand, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
fisterc
