I'm another newbie to both Droning and Forums
mavicpilots.com
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Australia’s recreational drone rules are designed to keep you and others safe, on the ground and in the air. Here are the rules you need to know now, before you take-off.
www.casa.gov.au
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
