Yours videos must be stunningHi jaybee,
the sunset is without a doubt very beautiful...But with over 6 minutes way too long! After 20 seconds you've seen it and then it gets boring because nothing new happens!
Only my humble opinion!
cheers Paul
You seem to be resistant to advice! I'm sorry, but your 6 minute sunset is unfortunately - and I'm sure others see it that way too - much too long. Nothing happens during more than 6 minutes, except - as I said - the sunset itself is very beautiful. But no one will look at the 6 minutes! A video should consist of different elements.Total views, half-total, very close, up to the close-up and so on. Then, when editing, make sure you have a good mix between the different shot sizes. Then, when editing, you should make sure that you have a good mix between the different shot sizes.I could pick holes in both of them but I am not a bitter man
Hm...what should I have noticed?You dontnt really look at that video or you would have noticed ?
I did not want to piss on your leg, but only help to make better videos!
cheers Pauldo you always lecture
oh you are so wrong man! I am not a German, but I am a Swissman!A typical German always lecturing. I served in Germany for 4yrs your typical
unbelievable! People like you should be banned from the forum! No idea of toot and blow and certainly not of how to make a video!It's wasted on you bye
Take a better man than you to piss on my leg trust meYou seem to be resistant to advice! I'm sorry, but your 6 minute sunset is unfortunately - and I'm sure others see it that way too - much too long. Nothing happens during more than 6 minutes, except - as I said - the sunset itself is very beautiful. But no one will look at the 6 minutes! A video should consist of different elements.Total views, half-total, very close, up to the close-up and so on. Then, when editing, make sure you have a good mix between the different shot sizes. Then, when editing, you should make sure that you have a good mix between the different shot sizes.
cheers Paul
I was trying new things out mateSorry John but interest factor wanes after a few seconds. The playback is jerky (may be YouTube) and way, way too long.
Hi SkyeHigh,Sorry John but interest factor wanes after a few seconds. The playback is jerky (may be YouTube) and way, way too long.
and waht exactly you did try out?I was trying new things out mate
Video is running at 50% speed and was at 2k and the drone is flying towards the sunset and then it's flying backwards.if it's Jerky will be youtube or it would run right through the video. Nothing ventured nothing gained as they saySorry John but interest factor wanes after a few seconds. The playback is jerky (may be YouTube) and way, way too long.
Well at the moment I am held back as I need to upgrade my pc and then i would use resolve. Editing just now on powerdirector which is OK but It has its limits , ie 2.7k at 60fps isn't on the list for editing. At present I have a m2p but new laws in UK ie drone code can't fly it in the city so bought a mini2 . Will upgrade pc nextNo worries Mate. The 50% speed change is what’s causing the jerkiness. Might be worth applying a motion blur to smooth between frames if you can. Ideally filming at twice the required frame rate will enable better slow motion playback - not always an option though.
What are you editing with?
