No image transmission/Glitch
Upintheair11
Hi there,
Since two weeks i've got a problem on my mavic pro 2, i've got rose glitches or sometimes no image at all on the phone. But i don't have any error code. My phone is connected to the remote controller via the original RC cable.
What i did :
- Reinstall the app
- Updated firmware
- Change SD Card
- Change cable
- Compass/IMU Calibration
- gimbal auto calibration
My phone is Xperia Z5
Any ideas ? Thanks in advance !
74617
74616
Sometimes when the images have distortion or cut out it could be a loose or damaged cable. Try physically unplugging and replugging in the gimbal. I would also recommend trying a different device to make sure the issue isn't isolated to your phone and ensuring that camera settings are set to auto.
-Kale
Thanks for your answers, i already tried with the usb data of the xperia z5, but same problems...
Yes I also thought about a damaged cable but personally I'm afraid to disassemble my drone, i think that will have to send it for repair :/
Ok, I now know what the problem is, but I do not know how to solve it.
I lose the image transmission when the gimbal is positioned horizontally (image 1), but when I turn it a little at an angle (image 2), i get clean image and everything works great. But i can't fly like that and it would be problematic anyway.
Is this a cable damaged or something ? Please don't tell me i have to change the gimbal entirely... Thanks again
Image 1 :
74623
Image 2 :
74624
I’d guess an occult cable wire fracture that get enough contact to function when the drone is tilted and the gimbal moves relative to the drone.
Reactions: Upintheair11
Thank you...
Yeah i want to cry, i will send it for repair with cable change then... Could be worse, a friend of mine lost his drone last week in the sea... it just dropped in the water and he doesn't know why.
Reactions: globetrotterdrone
You should have him post the logs on this forum. They might explain what happened and give him a fighting chance of a warranty replacement if it shows a DJI fault. If it is out of warranty DJI might offer a discount on a replacement.
drohnenfuchs
