The user manual has this caution about RTH;
"If you move the throttle stick (left joystick) after the aircraft rises above 65 ft but below the preset Failsafe RTH altitude, the aircraft will stop ascending and immediately return to the home point."
I never liked this feature and had a feeling it would get me into trouble one day. Today it almost caused a crash.
I was flying in a park with tall trees all around the Mavic. My return to home set altitude is high enough to easily clear these. As I was descending between the trees, the video screen went blank and my RC signal started going in and out continuously.
The first thing you think about is to get some height and get signal back. So I held the left stick up not really knowing if it was actually going up but hoping for the best.. After about 8 seconds, video returns and I can see the Mavic returning to home and just barely clearing the height of the trees. Obviously I lost total signal and the Mavic was RTH. The signal likely returned a few moments before I saw the video clearly and I had no time to react to the near miss.
My left stick input stopped the Mavic from first going to its total RTH set altitude and proceeded to horizontally return. I got lucky that it was just high enough not to crash.
I know I should watch the screen more carefully and be aware when it disconnects to not react, but its something easily forgotten if you don't fly for a while and keep up with continuous manual studies.
In my situation the signal was at first, coming and going. You get nervous about losing your aircraft. You are thinking "maybe I still have a little bit of signal there". The natural reaction is to gain height and try to get signal back.
If the Mavic returns to home after signal loss that's great, but it should continue to go to the full set RTH height even if the controls are moved. Only cancel should stop it.
Not a fan of the feature at all.
