Odd message while landing MA2.
k9kids
Dallas, TX
This is a new message for me.
Anybody else had this happen?
Battery was certainly installed properly.737EE264-E1D6-4956-B382-BEDB9EB3F277.jpeg
I will ask the obvious....was the battery positively locked in place??
seems odd
First for me...so what did you do to correct the problem?
As iaincaradoc says most probably battery swelling causing a slight disconnect, were you flying using sport mode ?
I’m going to write this off as a fluke and will continue to monitor.
No noticeable battery issue, swelling, or update availability.
Thanks for all your inputs.
Flew earlier this week and no request for battery update. First pack this morning and it asked so I updated and everything was fine. Second pack same thing but then I got that warning. I powered everything down, checked the battery and still got the warning. It happened twice then cleared up. Flew half a pack, came back and got the watning when I landed. I will not be updating my 3rd battery.
Your getting that exact same install error or a different warning. ?
Just to clarify when you first got your battery did you use the Single charger to activate it or did you use the Multi charger
I recieved my MA2 from bestbuy on release day (preordered) charged with multi charger and was one of the few that had zero issues. On that day I I updated all the packs as requested from the fly app.
I think that is the problem that the activation was not valid.
its the only thing that makes sense as to why that warning is happening . Do you have any batteries that were only activated on the Single Charger. ?
Phantomrain.org
Coal
Phantomrain.org
Coal
3 months with zero issues? Side note, I flew that pack yesterday after recharging and it was ok. Maybe it needed a charge cycle after updating.
Reactions: Phantomrain.org
hughesthis
