Official Mavic Pro Range Leaderboard!
Around 680g with DJI battery.
Estimated 1140g with 8Ah battery mod.
Time to dust off this science project and put it on a diet. I have been wanting to test 3x mavic battery cells but got busy, now I have an excuse :)
Warning: if anyone tries this mod and if you don't plug in the balance cables first, you will immediately brick the battery controller. I have a whole separate thread on this one.
Will that work the same with 3 aftermarket packs? I'd like to run 3 x 4500 and have voltage displayed at least.
Already working on Mavic #3. This will be the longest range build with 2 batteries inside with the option of a 3rd external top or bottom. I need to widen the area between the front arms by 12mm to get the CG where I want it.
Carbon tow plus epoxy will make for some interesting custom bodywork.
Battery leads straight on to the esc board. No DJI battery circuitry anywhere. I'll hang a voltage display in front of the camera if I have to.
Enough talking, time to go flying. My takeoff weight went from 1399 to 1329 grams. Isn't she a beauty? A face only a mother could love :)
Lolo, have you done a grand total weight loss measurement yet?
@JakeMaxxUAV
30,308ft tonight, another stock battery record. More favorable wind tonight and turned around at 43%, but temps were lower and the battery was running low 30's C most of the way.
27,969ft on the test flight landing with 7%.
Low voltage landing kicked in 250m out over a field full of deep wet grass. This is how it looks out of my car window. No way in hell I was going in there for the bird so I nursed it the last bit over the power lines with full left stick and just managed to brake the descent into ground effect and land it.
NOO!
@JakeMaxxUAV
27,969ft on the test flight landing with 7%.Low voltage landing kicked in 250m out over a field full of deep wet grass. This is how it looks out of my car window. No way in **** I was going in there for the bird so I nursed it the last bit over the power lines with full left stick and just managed to brake the descent into ground effect and land it.
WOW .Thats impressive.Great job
Oh my! Wonderful. Looking forward to the end result of this one.
@JakeMaxxUAV
NOO!
Great flight!
Did you note takeoff weight?
Can you post an airdata URL for this flight?
608g on the test flight and 600g on the 30k ft flight.
Will look at the data when I get back to the shop.
@JakeMaxxUAV
NOO!
That weight cutting is really paying dividends! Can tell on flight time.
keem21
