Oil props axis ?
jpblcm
Hello,
I've done more than 180 km of flight and I ear some "new" noise when near propellers. I ask if somebody drops some oil (fine oil for precision mechanisms) on the propellers axis ? as maintenance ? or it is really non sense ?
Thank you.
Ok Guys, thanx for your answers. I'll change the props to see if it changes the noise.
I read somewhere that if you dont unfold the props before starting the motors it causes more stress and wear on the props pivot points, not sure if this is the actually true or correct but after reading this I just roughly position the props in the open position, cant say if doing this has cause any less stress or wear on the props pivot points because my platinum in fairly new.
Thanx for your answer, I always unfold the props and always warm up the motors for 30 seconds. I'm never brutal and I use sport mode only when needed. I'm 80% in cinematic mode to film. I've changed the props, (always dji model) and the noise is gone. I took a closer look at the props with a magnifying glass and two had really little slits quasi invisible at the end of the props when the painting changes. Less than 2 millimeters.
So I post for nothing, I was careless...
Sorry for the "noise" I made myself.
LeoleoLeo
