PANIC TIME lost RC
flybigR1
Memphis
I was out on a flight path I've flown often , when out of the blue I lost RC connection . At that moment I realized I didn't know what to do ? Thank goodness after about 30 seconds RTH
took over . My question to the forum is
If RTH hadn't SMA , what could've I done to regain control before total panic locked me up.
You can also try to move closer or change your position to send a stronger signal out to the aircraft. But usually, once RTH kicks in, the drone will move closer to you so it gets a better signal anyway.
Reactions: dawgpilot
You can always get an alientech pro or 4hawks antenna with a booster. My connection is 5 bars up to about a mile.
Hatcher
