Panorama modes
speagles2
Australia
Hi all
New to the forum and new to the Mini 4 Pro. I was trying out the different panorama modes and made a couple of images to illustrate the field of view relative to the normal frame (the red box in the images below). I thought I'd post them here in case anyone else finds them helpful:
Sphere mode - 35 photos, 360 degree panorama, final resolution 12,000 x 6,000
180-degree mode, 21 photos, final resolution 12,000 x 4,352
Wide-angle mode, 9 photos (3x3), final resolution 8,000 x 5362, produces an image with essentially the same 4x3 aspect ratio as normal but with a wider field of view.
That's interesting and helpful. Thanks.
Not a big thing, but it looks like the aspect ratio on the first normal field of view rectangle is about 1.25 rather than 1.33. It's a bit closer to square than the other two.
Yes, the red rectangles are 'indicative only' :-) I just eyeballed it from the central photo in the panorama set and drew the rectangle by hand to match, I didn't bother to lock the aspect ratio to get it exact.
Reactions: MS Coast
d-dot27
