Payload limit?
hurunge1
Finland
I have an idea to make a thermal camera and the drone would weight about 120g extra.
Would that be a problem to fly with?
I red somewhere that that a guy could not fly higher than 5 meters and like 30m away when he adderad weight to the drone, coukd this happen and if so, what is that limit?
Reactions: kentdavidge
whenever the mini goes into payload mode which limits how high and how far away it can travel, most version will allow you to go into the menu and turn off payload mode and go back to flying normally.
I have a Mini 3. You can turn off "payload mode" if it turns on. I'm not sure what the maximum payload would be though. I know it turn on automatically if the prop guards are installed.
I run 120g payloads on my Minis all the time . You can expect a 30% hit in battery life
DJI Mavic Mini 3 or 4 Series Dual Mount for GoPro-Lighting-without Lights NEW If you can get a thermal camera to work on a mini that will be quite a engineering design achivement
Flight time takes 30% more battery power with 120g payload . You also need to balance payload around CG (if possible)
mini3user
