Pic Download Help ??
GregE
Wetside WA
I took some medium altitude shots of the house to the MPP mini SD. Tried to view them and apparently I have to do so thru DJI Photo Gallery. I didn't format the SD- is that required? Each pic is 23K KB and is DNG.
This laptop HD is nearly full- Is there a work around to get these open for viewing / forwarding? If not where is the PG link? Just saw the application is DJI Assistant 21.2.5 Loading that- hope I have room ...........
Search didn't help
DJI assistant dl complete. Still can't open the SD photos. What am I missing?
Found some small pics on the IOS, can't do anything with them.
Found out the pics are RAW and I'm not set up to open or edit that. Hope I don't have to retake after changing the pic settings on the MPP- i''s susposed to rain thru Sat and I need to be able to copy the pic Friday
Thanks.
Downloaded the Darktable and selected JPEG on the controller. Looks like I have some sun for a while so I'll take some more pics. :)
Reactions: THE CYBORG
Just in case you're not aware a DNG file is a digital negative or raw file which is similar to a film negative in that it needs to be processed whereas a jpeg file is a processed image. There's usually a small jpeg file embedded in a raw file to help applications preview the image.
If you're not wanting to process the image yourself you can set the Mavic to output jpeg images instead.
Reactions: GregE
JPEG for now. RAW can wait until I get some flight experience ( and some honey do projects )
No more Beginner mode. Flew tucked up to trees to get a pic of deck and roof and the MPP held steady even with the breeze blowing toward the trees.
Pay no attention to the guy in green
Flight paths. Large field soon, I hope
Spiff E.
