So I guess the 5m minimum POI altitude is for safety but what if your POI is below you?
What would you do?
What would you do?
I know you are using DJI Go, ...
Excellent. Just the advice I was looking for. Thank you!
I know you are using DJI Go, but If you use Litchi you define the location of the POI by tapping on the map, then enter the height of the POI relative to take off and this figure can be negative. Then the gimbal will face down to point at your POI. Unless you fly down to its lever!
Its safer than having to fly right over the POI to set the position, or down to its level. Say you want to film a small event - you can't fly over the stage or anywhere near all the people. But you could define the POI on the map and let the Mavic circle round a safe distance away never coming near but still pointing at the subject.
Also, when using Litchi POI - you can plot the required radius on the map and can see if your chosen path brings you near any tall objects (like trees round a church tower!)
