This is well worth finding out as it seems a good way to lose your drone.
Ive been using POI orbit over a mile offshore "safe" in the knowledge that if i lost controller signal it would come back to me.
If what you say is true then having the thing hover out of range isnt a good outcome. If it initiates RTH as part of failsafe RTH its better than nothing - the flight is a loss but the drone is saved. Worst case it keeps circling until critical battery and lands in the ocean.
Not sure how to test this unless you have an area of flat open ground you can orbit and allow it to potentially force land though.
Id want to know the answer though because it might mean using POI or other modes as i do would be too risky so id have to stop.
Not good news after testing RTH with controller switched off (disconnection simulation) in Point Of Interest mode.
I set battery warning to 50% hoping RTH would be triggered if signal loss happened, by deliberately turning off the RC at 51%. But Nothing happened, at time index 14.43, it just kept on circling.
Critical warning was set at 40%, I didn't have the courage to test that one. Just as well as i had a problem a few seconds later.
The video shows it just keeps on circling, and shows how long it was disconnected.
THE PROBLEM: Eventually when i turn back on the remote control, I had no control, as i wanted to actually fly home at time index 14.25, look at the controller sticks, there is no movement at the 14.25, and i am not very far away. how ever i regain control later on when i cancel RTH.
So I quickly initiate the RTH on the controller, the APP was not showing any values, height, distance, speed ect, it said N/A, so i did not trust the APP at this point, but had video feed, strange.
I only use RTH on the controller as a last option.
I have not tested the other smart tracking features yet, but i certainly will not be using POI at distance.
If there is a fix to this please let us know, many thanks.
Dropbox - ScreenRecord_2017-07-14-15-57-21.mp4
