Power System hardware error code: (16100069)
FarmerDrone
lancaster pa
Hello,
Does anyone know anything about the following error codes and how to fix them??
Esc error. code: (1608002F)
This is on a DJI Mavic 3. with a DJI RC PRO.
I was returning home from a flight and had some very strong headwinds, I was flying around 200 ft. to able to move ahead toward the winds, unfortunately the drone battery died before it fully returned home. I seen what was happening and was heading for a open field and at that point flying around 100 ft and dropping fast.
I lost connection at about 50ft and it came down on top of a tree. I did find the drone and a few props were broken but no other physical damage that I could see.
There were a few small pieces of the props and some dirt in 2 of the motors. I cleaned everything and put a fresh battery in it.
The codes above came up and of course I was unable to fly.
Any advice or help would be greatly appreciated.
Thanks in advance
According to this video, you might be able to clear the error by going into DJI Fly > Settings > About and then select "Reset All Settings"
Aaron Steele
