Pre-flight Issues
flyingcow
Genève
I am having pre-flight issues with my Mavic Air (see picture). Two flights ago, I had a semi-hard landing (drone landed at an angle and the front two arms folded back). I since flew another time with no issues. Now I don't even want to take off.
Any advice is GREATLY appreciated.
You can start by re-caliberating the IMU and see if that resolves anything. Unplugging and reconnecting the 8-pin cable connecting the dampning plate and aircraft is also something you could try if you are technically minded (see thread from another member who had similar issues below for more on this). But, and I can't stress this enough, it is better to have the aircraft inspected by a qualified repair service provider if there is one near you or contact DJI support. That is a lot of errors and it would not be wise to fly with this aircraft until you are certain it is flight worthy.
Sounds like loose connections or faulty board from the crash. Get it inspected for ssure. Not worth risking a total loss.
Do you have dji care?
Liger210
