Private Instruction in Westchester, NY
SMK
Bedford Corners, NY
I’m very new to the drone community - I just purchased a Mavic 3 Classic with an RC controller. I’m looking for some private instruction before venturing out and making some critical mistakes. Is there anyone in the Westchester, NY area that may be interested in some billable hours for private instruction? I have access to a 17 acre private property with manicured gardens, lawns and ponds. It is located in the Bedford Corners / Mt Kisco area of Westchester.
Reactions: GFields
If you're not able to find one on one help, there are plenty of Youtube videos. @pilotinstitute has some great courses too.
Welcome to the forum one more vote for Pilot institute
I did a quick Google for Drone services in Westchester, NY and this came up… Also, check the Members Map for folks near you and PM them…
You can call them as you wrote you are willing to pay for instruction… or do some more Googling
Also…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 3 Classic, including the User Manual.
Fly On and Fly Safe…
Not sure if you use instagram but check out Jerome Strauss his instagram name is @jsdronephotography
He is from Westchester and flies daily, arranges meetups to fly. He’s really a great guy I’m sure he’d be happy to meet up with you and get you started or point you in the right direction.
Reactions: LoudThunder
I live in Yorktown. Have been flying DJI quadcopters since 2016. Also have Part 107 certification. Not interested in financial remuneration. Being a former schoolteacher and business owner, I've successfully taught several others to fly quadcopters. If interested, reach out through: www.martymarkoephotography.com
Contact page
dvkhamtruocsinh
