Pro platinum to iPad pro11
Tejo
Uk
Hi , I was wondering if there was a cable that I could use to connect my pro plat direct to to my iPad Pro 11 . What ends do I need. I know the iPad needs a usb-c but what is The other end ? And would that save me from having to pull the sd card out? How and where would the pro plat show up on my iPad? Sorry bout all the questions .
Standard USB-A (the big one) and connect it to the bottom of the rc instead of the little on the left side, don’t forget to disconnect the little USB-B ”lookalike” where you usually charge, Otherwise you will not have a connection.
Yes I have that one for connecting the remote , but I was wondering if I could connect the iPad direct to to my drone to get the footage and pics directly into the iPad to save pulling the sd card out. As I only use my iPad and use luma fusion ( which I have just bought ) to edit .
thanks for replying .
Ok, now I’m with you. No the best choise is to take out the SD card and the quickest way to copy your photos and movies. I also have a Ipad and I use a adapter for this. When you have RAW files it’s a must.
From SD card reader to lightning.
SD to lightning won’t work. Pro 11” has a USB C connector.
One of the good things about the current IPad Pro models is they ditched the lightning port and replaced it with USB-C. Any USB-C card reader should work.
What connector does the Pro platinum have?
And you don’t have the SD standard adapter that comes with the micro card?
I do, a lot wont. Recently it seems Micro SD cards are sold with a USB reader. USB-A to Micro SD adapter would probably prove a better investment as it can serve dual purpose- connect external drives also.
ben_h_17
