Problem focus camera
magosagazzu
Italy
Hi guys, congratulations on the forum, very well organized. I have for some days the room of my air which is not in focus. I think it took a hit and I didn't notice. Is it possible to adjust the camera optics by removing the glass?
sure, but I can't work like that. the images are very blurry.
You can remove the filter ring and filter, but this would leave the lens exposed. I'd probably get another UV filter to protect it
Reactions: magosagazzu
I need to know if by removing the original glass underneath I can slightly rotate the lens to bring it back into focus correctly. Then I put an external uv filter like that of the face to protect the optics.
I would say you cannot do that
Have you got AFC turned on and also if you tap the screen in camera view mode does it focus on what you tapped ?
Friend, MA1 has fixed focus and does not have autofocus like other mavic models, this item is not in the camera menu
I solved by replacing the cam but everything works fine except error code 3 when starting the app
Freakazoid
