I just bought a smart controller online, the previous owner states it is brand new and never used. I just plug it on the charger and only blinking white at 1 bar. Is this charging or it charging super slow?
You know you have to press the Power Button, ONCE and then a SECOND time in quick succession to power it on. It is kind of like the drone - two presses of the battery button.The problem is that I can't even turn it on.
I'm using the Larger AC power supply used to charge the Intelligent M2 batteries that also has a USB port on it . I don't have the original controller charger at this time with quick charge. I will be getting it tomorrow from other shipment.
Yes that is what I did and I even held it for 15-20 sec. It only blink all 4 white light at the same time and back to 1 solid blinking white light.
it could be that it has been left with a really low charge for a long time and the cells have gone bad, if you can get an original charger made for the SC it may kick back into lifeAt least 1 hr. Could it be over discharge?
If it has not been charging long, it may not have sufficient power to turn the screen on. I'd give it an hour or more..
Here's the one I purchased. From all appearances, it is the one from DJI
Genuine DJI 24W Intelligent USB Charger for Ronin Smart Controller QC24-US for sale online | eBay
Find many great new & used options and get the best deals for Genuine DJI 24W Intelligent USB Charger for Ronin Smart Controller QC24-US at the best online prices at eBay! Free shipping for many products!www.ebay.com
it won't hurt but don,t leave it unattended while on chargeGuess I will have to wait till tomorrow, to get the original charger from the post office. But should I still keep it plug in with the Mavic 2 charger plug?
Actually on mine I only need to press and hold the power button (upper right) for about 3to 5 seconds till it vibrates, and then let off the button. You press the button once briefly to check the charge level. Hopefully it is only because it is on a slow (low power) charger. Otherwise the battery could be junk which would require a battery replacement surgery. Luckily it is a USB C connection, and not plagued by the plugging the connector in up side down like the standard controller was. Anyway, the lights should eventually progress up until all 4 are lit.You know you have to press the Power Button, ONCE and then a SECOND time in quick succession to power it on. It is kind of like the drone - two presses of the battery button.
Yes, that is how I power my SC on too. Just hold the power button down for a bit until the SC vibrates.Actually on mine I only need to press and hold the power button (upper right) for about 3to 5 seconds till it vibrates, and then let off the button. You press the button once briefly to check the charge level. Hopefully it is only because it is on a slow (low power) charger. Otherwise the battery could be junk which would require a battery replacement surgery. Luckily it is a USB C connection, and not plagued by the plugging the connector in up side down like the standard controller was. Anyway, the lights should eventually progress up until all 4 are lit.
