Problem with dji mavic pro that the camera does not go up or down
Noam
Problem with dji mavic pro that the camera does not go up or down, what to do?
You mean that the gimbal control wheel on the remote doesn't work?
When you power up the aircraft, does the gimbal do the normal self-calibration (move around to all sides, then center)?
Try this:
  1. Turn the aircraft on (do not start the motors, doesn't matter if the props are on or not)
  2. Pick it and hold it in front of you
  3. While looking at the camera / gimbal, tip the nose of the aircraft up and down slowly (not too steeply, just enough to observe the camera / gimbal action)
  4. Do the same thing while tipping the aircraft to each side
When you do step 3 and 4, you should see the camera remain level to the ground.
If it doesn't, then you have a bad aircraft. If you just bought it, return it, but you could try to do a manual Gimbal Calibration (in the DJI GO 4 Gimbal menu).
If the gimbal does seem to be working, but you still can't make it pitch up and down with the remote control gimbal wheel, then you may have a bad remote control. If you just bought it, return it.
Also, you can try to tilt the gimbal from the DJI GO 4 app by dragging on the screen. See 2nd paragraph at the top of page 37 in the owners manual.
Chris
jimi79
