programming googles
Very hard to help without knowing what / where the issue is . . . step by step guides aren't hard to find already.
Probably the best way is to read up the respective goggles manual.
Not sure it you have white or RE ? Here's both . . .
or . . .
If this has been tried without success, at what point is connection failing ?
Youtube has an immense number of self help videos too on this . . .
Google search for > dji goggles M2P
Hope that helps you get it sorted, as they are great with the M2P, you should fly very conservatively to start, and add new things once comfortable flying at a basic level, much like when as a new pilot you learned to fly the drone itself slowly and safely.
Thanks, and i do have the white goggles, and have linked them before. This time they would not link. So I connected to computer and downloaded and update thru the DJI assistant 2 App. There was an update there so maybe that was the issue. I will try again this weekend- Weather providing;-) Thank You.
Reactions: MAvic_South_Oz
frankiesamusementpark
