Prop Replacement
markj4
Hi,
I’ve had my Mavic about a year 14 hours,298,000 ft,no crashes.
Still using original props. When should props be replaced even when they don’t show any damage or wear?
Thanks
You only need to replace them if they are damaged. I'd recommend also replacing them if you strike something and don't notice any damage (since the hub structure could be compromised).
31 hrs, 430,000 ft, 390 flights, same original set of props.
iconautomatedsolutions
