Propellar guard advice for Mavic Pro 2: DJI or Pgytech ?
Bahadir
San Diego
I'm planning to fly my MP2 indoors and occasionally in the woods, so I'll be needing propellar guards. People are pleased about these two brands: Pgytech and DJI. I wonder which makes less drag or burden for the drone.
It would be hard to find anyone who has used both to be able to provide a comparison.
But it most likely that both are fairly similar.
That may be right. At least this is the best place to ask and hear opinions. Already learned yours for example : )
Btw, net weight of Pgytech set is 88gr. whereas the DJI set is 78gr. I'm not sure this weight difference alone might make any discernible difference.
Hi @Bahadir .
I just googled both sets, and from the photos, not much difference in function.
A few things I noticed.
Weight of 10gms is not going to make much difference to the M2, but the slightly heavier ones MIGHT be marginally stronger . . . though they are slightly different shapes, so this might be where the weight difference lies.
Both are 4 pieces, using a clip to join.
Looks like both might take a bit of fiddling with during set up.
Both are simple 'bump' prop guards, that is they will help fend the drone off a wall, or a tree trunk, but neither will do much at speed, or in finer foliage.
Both seem to be about the same price.
Good luck with them.
I have the M1P DJI prop guards, used them once and tested on a house wall, worked fine.
Haven't used them since, another 'thing' hanging around like the leg extensions, lol.
Hi @Bahadir .
Thank you for your extensive reply. Apart from 10gr difference which would not make a difference in flight but would make the Pgytech a bit durable as you pointed out, there's a negligible price difference too, the Pgytech being 23 dollars and the DJI 31 dollars. Actually if I wasn't planning to fly it indoors I wouldn't care about such an accessory either.
Reactions: MAvic_South_Oz
CMDR DV TEARDROP
