Propeller/Motor Malfunction
Sam_B
England
I was flying my MM over a river, and looked down at the video, it suddenly flipped upside down (not my phone, just the drone)!
I heard the motors shut down, and it plummeted into the river at about 7m/s from about 25m high (according to the flight path/playback in the app).
I think what caused this is a single motor malfunction (one motor stopped spinning - causing it to flip over - causing all the other motors to stop spinning!
Anyone else had this problem!??
Welcome to the forum and someone will ask to see your files to help locate the problem.
Do a search on this forum to get that info.
Tha attached shows the path or folder chain to flight logs using an android phone and a windows PC.
Iphone and windows needs itunes on the PC.
I think Iphone and MAcbook needs itunes on Macbook .
'Oddly'? Linux sees the logs on an iphone as easily as windows does
I think the DAT file is probably going to be of more use, it will have a name similar to
2021-02-06_`15-mm-ss_FLY058.DAT it should be in the MCDatFlightRecords folder..
No video
Here's what your flight data looks like:
It shows that there was a problem with either a front motor or a prop.
You were flying in Sport Mode 17 metres higher than the launch point and descending further.
At 15:33.3 something goes wrong and the Mavic starts to rotate anti-clockwise as it tips forward.
The drone is soon spinning and wobbling as it loses height.
The drone did not roll upside down and power stayed on.
Signal was lost at 15:32.2 with the drone almost into the water.
Have you watched the video footage, because it clearly shows the drone flipping upsidedown.
Crash video can be confusing.
The data shows that the drone never rolled more than 73° to one side.
But the gimbal gets hung up when the drone rolls further than it can counteract and the view from the camera's perspective is what causes the confusion.
Any chance of you going fishing? How strong is the current in the river?
The DAT might have shown the motor speeds which would show if a motor jammed or slowed significantly or sped up if a prop blade came off.
The other logs were of no use to me sorry.
The river is very murky, and the current is quite fast. I'm fairly certain it went straight down, but it would be too muddy, fast moving, and cold to retrieve it I think.
And even if I did find it, it would be destroyed from the water anyway!
Fair enough. The reason for asking was, if you recovered the drone it might reveal a jammed motor or missing props etc, and there is a slim chance there might be a DAT on the memory card.
Do/did you sync your flight logs with DJI? If so it might be worth asking them if they have a copy of the DAT whose name ends FLY058.DAT
Yes that is what I mean and it looks like you do sync, they may have a copy of the DAT.
Humbug4
