Question on pics and videos with RC 2 and Mini 4 pro.
JohnDS
Long Island, NY
I bought a 512gb micro sd card with plans of recording video and taking pics, not realizing there is a micro sd slot for both the RC 2 and Mini 4 Pro. So I installed it in the Mini 4 Pro.
My problem is that while fI was out lying, the controller has a message on the screen that says storage full. So when I got home, I took the sd card out of the drone and put it in the RC2. Then I changed the settings from internal storage to sd card, then back to internal storage because I decided to put the sd card back in the drone.
So what I found weird is, while the sd card is in the RC2, the storage full message is gone and I am able to take pictures but no video. But when I put the sd card in the drone, i can take video, but no pictures.
What do you think is going on and why do they both have sd card slots? Should I get another 512gb sd card to install in RC2 to as well?
There's really no good reason to have a card in the controller.
The message is about the internal storage in the controller.
The card in your drone isn't the place to store imagery from many flights.
You don't need a huge 512GB card.
You only need a card that's big enough to hold the number of image files you are prepared to lose in one incident.
It's a great place to put a spare card for that inevitable day when you realize that you're out in the field without a card for the drone.
I’ve put 128GB in both slots just in case. The drone uses Quick transfer to copy anything good/useful to my iPhone. So far I’ve not deleted anything from the drones card and it’s good to see every photo when I plug it into the laptop. And when I do leave it in the laptop it’s like MS says, the RC2’s card is a handy backup.
Also, if you want to record the screen image with telemetry, it's much easier to have the RC save it to the card rather than the RC internal storage.
So what do you guys think the issue is when the sd card is in the RC2, I am able to take pictures but no video. But when I put the sd card in the drone, i can take video, but no pictures?
Also just so I understand, when I click the buttons on the RC2, are the pics and videos saving to to drone memory card or the RC2 memory card?
Just for the hell of it - have you tried installing a smaller capacity microSD card in the drone? say... 64gb, or 128gb.
No I have not. What is the recommended size?
Right now I have a samsung 512gb sdxc 180mbps write speed and 130mbps read speed, and just ordered another. Oops.
The recommended size is just big enough to hold all the imagery you are prepared to lose in one incident.
If you value your work it's not a good idea to store weeks of work on the SD card in your drone.
Reactions: GadgetGuy and wdfly
I never run multiple flights without dumping and formatting the card in the drone. As a photographer, I have always done this with my cameras, with my modern cameras, I run 2 cards in them in case one craps out.
Maybe there's a setting for video that is preventing its use...just guessing
New here sorry in advance for dumb question
I read some comments that there is no point in having the sd card installed on controller (rc2) instead of drone
What if you crash it or lose it and can't retrieve it? Can you save photos and video directly on controller?
The link between the drone and controller does not have enough bandwidth to control the drone and send back full-sized images or video.
If you are concerned about losing the drone and the imagery on it, it's a good idea not to have a large accumulation of saved work on the card in the drone.
My work is important so I use multiple cards and swap the used one out and replace with a new one each flight.
You always need a card in the drone, so it's not an either/or choice. One good reason for keeping a card in the controller is that it will save the day when arrive at your flight location and realize that you left the card in the computer after your last downloaded files.
Do you know if using the cellular dongle does the bandwidth or the signal quality increase?
It increases the delay in responsiveness. The signal quality depends upon the current congestion on the cell network and the strength of the cell reception in the area where the drone is currently flying. It also only works when the OS4+ signal is blocked, and it cannot be selected exclusively. It is designed to supplement OS4+, not replace it.
To learn more about it, check out this thread:
Reactions: vasilis_03
Dogbone06
