Quick Q on Waypoint Hyperlapse
Dakrisht
Southern California
Trying a few waypoint hyperlapses but confused about length.
Of the three I've done (two waypoints set), I'm not seeing the ability to change duration / length of the hyperlapse anywhere?
In Manual hyperlapse mode, you can set both of these values and make a 10+ second hyperlapse.
Am I missing something or does the M2P simply not allow you to set length / duration of a waypoint hyperlapse?
5-seconds is the current max I'm able to shoot with waypoint hyperlapse mode, ideally 10 would be the ticket.
You set the length of the resulting video -- that defines how long the flight goes on taking shots (the longer the video, the higher the shot count). You can set this longer than you need and just end the flight early.
Are you saying there is a 5-second max to the Interval setting?
Chris
Chris
I get that but not able to see the ability to set the resulting video length / duration anywhere in this mode. Only the waypoints UI is shown.
In manual or course lock mode, you can chose the interval and the duration of the hyperlapse.
It doesn’t make sense that you can not select the duration of the shot in this mode while length is probably relayed to the waypoint A > B.
RobertCNewman
