Quickshots only in 1080p resolution?
projectarjun
New York, NY
I thought we could do Quickshots in 4K, any idea why my Air 2S decided to record in 1080p? I'm running the latest firmware :) Thanks
Thanks, will those settings save or do I have to configure that parameter every time I do a quick shot?
I’m not sure I don’t use this feature a lot .. i think you’ll have to do it again.. but you should figure that out after a couple of tries.
Reactions: projectarjun
I'm paranoid now... whenever I switch to a programmed mode (mastershot / quickshot) I double-check that it's not switched back to 1080p from 4K. Still it seems there's nothing you can do to get it to shoot D-log which is a huge dissapointment
No dlog in mastershots because the drone will apply zoom and you cannot do zoom in dlog
Yes, I realize that's correct, but I guess I'm wondering why. Why does the 2S have to apply zoom in mastershots, thus rendering D-log inoperative? Seems like they could just make the thing do the moves without zoom... but there must be some reason why or they'd have done it already.
Is it a software limitation or hardware limitation?
Daniil93
