Range Limitation fix with BT-300
nbrewer78
Did my first real flying or tried too anyway and was getting max range errors using the DJI go app.
I read posts about how when you log on with your phone it unlocks this as a safely feature but how do you do it with the BT-300?
Does the Soar app have the same issue? Is there a better app to use? I think logging in with my phone first seems like a pain.
I don't believe there is a difference between the two. You go to your setting and turn off the beginner mode (I believe that's what you've got going)...and turn off any range limitations...all of the setting that are on your phone are on the BT-300 version.
Are you using GO 4 or DJI Go? Go4 is appropriate for most of the newer drones.
nikt_elo
