RC battery indicator stuck on 100%
Resthill
Since the RC apparently thinks it got full battery, I got no warning before it shut down today, mid flight...
Luckily the drone did RTH as expected...
Has anyone experienced anything like this? Has any tips on what I could do to fix it?
I have re-flashed firmware 01.03.1000 from DJI Assistant 2. nothing changed.
When I try the "RESTORE FACTORY DEFAULTS" it just fails... Are there any hardware reset (button combination trick) out there?
Any help is highly appreciated!!
Have you been charging the battery and using it at the same time via a battery pack ?
It should recalibrate by completely draining it then fully recharging then draining it again.
No charging and usage at the same time... I've used a ipad on the big USB... I don't think there's any power going any way there? The remote has been all drained and filled up again... I'm draining again now... Maybe let it stay drained for some days?
So no matter what you do it says 100% ?
What does it say the RC batter level is on DJI Go under the status screen ?
I'll was going to fire it up to check... but got noticed about a FW upgrade. So now I'm trying this... It might just be FW for the drone but I'm trying to keep everything here up to date... V01.03.1000
And Yes: It just says 100% on the RC until it just dies....
Screenshot_20170827-225933.pngthis is an older image from My S8+ (Android). I normally use iPad. Where is the rc battery indicator located in the app?
15038692665111644606717.jpg can't see it anywhere on the iPad neither...
But now it's getting late here in Norway. Better go to bed and continue this whichhunt tomorrow...
Tap the red/green status bar, it's in the "checklist" table.
Yes it says 100% in the app as well. and now the battery is all drained... I'll let it stay uncharged for some days now and see if anything resets...
Birddog495
