RC N1 will not turn on
kmohr3
IL
Hey everyone, I just was going to get my Air2S and do a flight, and I noticed the RCN1 remote was plugged into the charger, but one light blinking. I tried to turn it on, but to no avail. I know I had the charger plugged in for a few days, but never had an issue before. Does anyone know of a way to do a reset or a cold boot with the controller? Has this thing just failed? Thanks!
What are you charging with? The most common problem as mentioned above check your cable! Try one and give it about ten or 15 min if the battery is still not charging try another, If that wont help I would ask hpw long you have had the controller It may be time for a Battery. Do NOT charge it unattended! at least not until it acts normally.
On button. Short press, then press again and hold a few seconds?
Thanks for the replies everyone - I have discovered that my charger had apparently quit working. Charged the controller with my Samsung phone charger and it started working again. So, when I plugged it in I was actually discharging.
Gavthistle
