RC2 vs RC-N2
GroovyGeek
San Diego, CA, USA
It seems that the general opinion is that the RC2 is a better option for flying a drone, but for the life of me I can't understand why.
  1. It has a pitifully low (by modern standards) brightness of 700 nits, vs 2000 nits for high end smart phones. That is a TON of difference for flying in bright light.
  2. The screen is only 5.5 inches vs 6.8 inches for high end smart phone
  3. If you are already carrying a phone anyway, the RC2 adds unnecessary size and weight
What am I missing?
Bonjour
Tout le monde ne possède pas un téléphone qui coûte 1200/1300€ première point.
"Si vous transportez déjà un téléphone, le RC2 ajoute une taille et un poids inutiles" seulement si on les porte 1 dans chaque main (humour). Je suis passé du téléphone à la RC2 que du bonheur. Très peut de personnes font le contraire, c'est un signe non!? A+patc45 bonne année à tous avec ou sans RC2!
All true, but it's so much simpler despite the compromise. There's no possibility of cabling issues. It works seamlessly and you're ready to go very quickly. You can keep your phone in your back pocket and you don't have it hanging on your controller. As for the size and brightness, that's the compromise.
What am I missing?
I can start filming must faster without having to install the phone. Simplicity is worth it for me. Besides, I need my phone while I am filming .
De plus vous pouvez avec votre téléphone filmer votre drone qui part, qui revient, en l'air, au sol ce qui est impossible si vous pilotez avec. A+patc45! sans oublier que vous pouvez aussi téléphoner (humour)
I translated this with Google- In addition, you can with your phone film your drone leaving, which returns, in the air, to the ground which is impossible if you fly with it. A+patc45! Without forgetting that you can also call (humor)
Totally agree
I typically use an iPad mini when flying. If it's over about 85 degrees, the screen goes dim. I'm assuming/hoping the built in screen doesn't suffer from this malady.
I used to use an actual Apple tablet but since I live in South Florida. where the average daily temperature is usually above 85 degrees Fahrenheit, I stopped.
Three words - balance, bulk, and elegance.
Thanks for the perspectives. I guess I was only looking at it from my own narrow need - primarily a hiking landscape photographer, where size and weight are at a premium, and I don't use the phone for anything else related to the drone.
I really like how the rc2 is so little. Coming from a P4P using an i pad mini and a sun screen. It’s a great setup but there’s something to be said about having an rc with the screen and software built into the unit and having a better connection to drone. Plus it has 04 transmission.
Have never needed to try as I don't fly out long distances. But I have watch a couple of videos comparing the two and both indicate the RC2 has less distance before signal loss.
Reactions: spamgnome
An additional reason is if you’re flying with a LAANC clearance as. You MUST be available at the phone for ATC. Managing a call while using the phone as your controller screen could be distracting and the phone cannot be in a “do not disturb” mode while flying.
Curious as to how many times this has happened to people...ATC calling them during a flight. I have to get LAANC clearance all the time and they have never called. I guess it could happen. If it did, and even if the phone was in my pocket, I'd land first and THEN talk to ATC.
After reading the comments here (and elsewhere) I opted to go with the RC-N3 controller. The number one factor for me was screen brightness. The iPad mini that I fly with now is not nearly bright enough most of the time, especially when it dims on hot days. The fact that the RC2 has an even dimmer display was enough for me. There were some other factors as well, but the screen brightness had the most influence on my decision. I can put the extra $200 towards a tripletek :-)
Reactions: GroovyGeek
I've never been called of course. My phone number is directly in the clearance as to how they are to contact me. Landing and returning the call is probably fine (if needed) but the wording is "Douglas McConnell SHALL be continuously available at (123
The clearance reads "Douglas McConnell shall be continuously available for direct contact at (123) 456-7890 by Air Traffic". They expect an answer when they call not a voicemail or a call back. That's my interpretation of that sentence. And you are right, I have never experienced that need. The language in the clearance is very simple and direct however.
fharrihill
