remote cable
MGM
Brenham Tx
My remote controller cable is too short to reach my IPad 4 plug. Can I buy a longer one and will it work OK
You can just buy a longer USB-C to lightning cable.
There are plenty of non-Apple sellers as well on Amazon, Monoprice, etc.
Reactions: Tony McDrone
I've been using the 11.8 inch version of this cable to connect the MA2 controller to a 10.5" iPad in this mount and it works like a charm - comfortably reaches the iPad with some slack, but is still short enough to wrap up and fit in the space under the controller's device holder where the original cord is stored. Depending on your mount, might be able to get away with the 6.3" version.
Hanatora 11.8 Inch USB C to iOS Nylon Braided Remote Controller
So there's nothing unique about the DJI cable? We just need a USB-C to Lightning charging cable and we're good to go?
Pretty much. I know there are some usb-c to usb-c cables that are charging only and not data, so double check that whatever usb-c to lightning cord you’re getting also supports data (I imagine most do), but otherwise you should be good to go.
Rythorne
