Remote Charger Cable
UpNorthStupid
Hello All
I just bought a used Mavic Pro on eBay which is missing the charger Cable for the remote. Is this some type of standard USB cable (which I would probably already have lying around) or do I need to order a specific type of cable?
Thanks!
Hello All
Thanks!
It uses standard micro usb. It look different, more square, but it is micro usb.
it's a usb port, but be carefull when you plug a usb cable as the port is a perfect rectangle while the micro usb connector is not!
While the external part will plug upside down too, the electronic connector inside will not and if you push it it, with time, the controller's port might recess cuasing issues! ;)
Once I determined the correct orientation of the plug, i put a blob of my wifes nail pplish on the top of the plug and on the controller. Get them loned up every time
Reactions: WAXMAN
Or get a reversible micro usb cable over on amazon. They do make those
What @zachschul22 said but be careful using it on the RC. The tab inside the RC housing won't withstand too many upside down installations before it breaks off. Then you have a real problem.
With the RC screen and controls up, the plug goes in as shown in the picture.
drones404
