Removing blur from film
mavicmaestro
uk
I filmed the mavic mini 2 with no filters
Lots of over exposure and lots of blurring around the edges
The centre of the film had detail
Went to curry’s and saw those lovely detailed super bright drone pictures on those hd TVs
I want to recreate it
Film at 1080hd 30fps
How do I get rid of the blur
Bought some filters cpl and nd8 nd 16
Many thanks
K
Sounds like something wasn't set right or working correctly. Care to post a link to an example, or upload a few stills from the video? It doesn't sound like lack of filters is the main problem here. ND filters are usually used to increase blur.
Got some examples to show so we're making sure we're talking about the same thing?
It should be the same sharpness across the frame on a Mini 2's camera, shouldn't be a large drop in sharpness on the edge unless something is wrong with the lens.
This does not address the actual problem, but one simple solution is to just crop the video in software.
It sounds as if the image is badly overexposed. Check the histogram. If it is overexposed and clipped, you are out of luck. Exposure set correctly is vital to good images. The DJI app has many tools for setting correct exposure, and filters can also be used if you need to control the shutter speed.
DA_Aereo
