Replace vision sensor module mavic 3 classic
tedequip
Pleasanton
After replacing the mavic 3 classic vision sensor module with a new one. It says “error sensor vision” and the drone does not take off. Any suggestions? DJi assistant 2 and RC calibration IMU were tried.
When it comes to those types of repairs, I send it to DJI
That's not a common error message. Can you confirm it states "error sensor vision" exactly?
If this error message did not appear before the replacement, then it's possible you installed it incorrectly or the new component is damaged. Parts like this are often harvested from used drones, and they might sometimes not be fully tested before selling.
And then if all else fails, try reaching out to a repair shop for help. If you send your drone into DJI for repair, they will likely send you a refurbished drone in return. So, just something to keep in mind if you're only interested in replacing the part itself.
vision sensor calibration error / Code: 16200202
You can search the Net for DJI number Matching services....Will cost you around 100 Bucks U.S.
doing what exactly? I have not used one of those services in a while and I dont do recommendations for any of them you just need to research the service you plan to use....I hope this helps.
The pic shown shows Calibration Errors...You need to start anew with your calibrations!
What is the above number???? (post 11) if its a contact number you should remove it!! only send contact info thru PM!
need help with the application since dji assistant 2 consumer series is not showing calibration
Reactions: Cafguy
Calibrate your Drone the way your Drones manual tells you. Do NOT skip a step and do not move to another calibration if the last one failed.
You MUST be in a place with great GPS reception NO metal around and NO CONCRETE!
Assistant 2 will not help you calibrate your Drone...Not that I know of.
If you cannot get the Drone to Calibrate you need to send it to DJI.
ok any Dji Centre close to or within Africa
I have NO idea check the DJI site for info...Sorry
BY THE WAY none of the errors you show are serial mismatch errors they are all calibration related.
DevonAnkunding
