Replacement Mavic DOA
When off, all appears normal. All seems to move freely. When i turn it on it tries to initialize, clunks around and stops facing downward. Gimbal will not respond at all.
Sent from my SM-G920V using MavicPilots mobile app
Is it pointing at 7 O'clock? If so, try gently rotating the lens counterclockwise right when it stops and see if it then continues its initialization.
Yes it's at about 7 O'clock. I tried helping it along with no luck. Dji has sent me a 2 day air label and promised to expedite. I have my fingers crossed.
Did you try "rotating" the lens? Don't bump the whole camera left or right, but actually try to rotate the face of the lens counterclockwise just a bit. I'll be surprised if that doesn't work for you.
dvkhamtruocsinh
