Replacing front left leg/stand LED, is there a trick to it?
oneeyedpilot
Tampa, FL, USA
Site
www.limelightdigi.com
Hi guys!
The other day when my air 2s came to an emergency semi-crash landing from ~870 feet after a battery malfunction took me from 30% battery to 0% without warning, the front left leg stand busted and needed to be replaced…
(Yes I know I’m EXTREMELY lucky this was the extent of the damage!!)
In order to release the original little LED board from the old busted piece, I actually had to cut the plastic hole on the top of the broken leg section and bend it so the board would come free, I couldn’t get it to go through the hole it’s SUPPOSED to go through to save my life.
I got an entire new front left leg assembly (two, actually, Amazon mishap) and I had no trouble unscrewing the intact replacement plastic piece from it to put on my drone.
However, no matter HOW I try to get that **** LED board back through that top square hole from inside the leg to the outside (where the lens cover goes over it), I CANNOT get the **** thing to fit through the hole!
Is there some secret trick to doing this? Am I not rotating it the correct way? I’ve tried straight through, I’ve tried at a diagonal, I’ve tried pulling it through with needle nosed pliers, all to no avail!
Would I be better off just busting out my solder iron, melting the connections from the wires to the LED board and disconnecting them, then passing the wires through the hole and re-soldering them back to the board on the outside? My gut tells me that’s probably the most prudent procedure, but I just wanted to check with y’all first to be sure!
Thank you!
Anna-Maria
@oneeyedpilot the unsoldering method is going to be the answer ,thread the wires through from the arm attach the leg after making sure that the antenna is correctly fitted into the leg,and also that you mark the wires correct orientation as LEDs are polarity sensitive
Reactions: oneeyedpilot
artyboy
