Replacing Mavic Mini Gimbal
rscheff
North America
I am on my 3rd mini, one replacement was under warranty, the other two were replaced under the insurance policy. My first replacement was because the gimbal kept overheating. It is now happening again, I get 2 error msgs. 1) Gimbal is over heating and 2) Gimbal is stuck. I have a feeling it is just a matter of time that it fails so I am looking for a new gimbal. My question is: Can you replace the gimbal in a Mini 1 with the gimbal of a mini 2? Might as well upgrade while doing it.
I have several mavic mini's and mini 2 one of the mini's has nearly 800 flights and the others all have 100+ flights. None has had an gimbal error other than those caused by a crash etc. or where something has been blocking the movement of the gimbal, including the cover being left on.
I would, respectfully, suggest that with three failures you need to look at your handling of the drone or the way you store it or the flying environment.
Are you flying, landing, taking-off in dusty conditions, are you loading the gimbal with heavy filters etc.
With regards to the swap, I too would say NO, a straight Mavic Mini for Mavic Mini swap is difficult enough and involves the use of some Java scripts, a Mini 2 camera may be even worse.
Aside from that, unless the Mini 2 camera/gimbal is being taken from a broken drone I doubt the swap would be economically sensible.
217.04US $ 44% di SCONTO|Nuovo per DJI Mavic Mini Gimbal Camera Assembly pezzi di ricambio di ricambio riparazione dell'obiettivo testa della fotocamera del giunto cardanico|Drone Accessories Kits| - AliExpress
I copied and pasted the above into Google Translate and it translated the Italian into this...
"217.04US $ 44% OFF | New for DJI Mavic Mini Gimbal Camera Assembly Spare Parts Lens Repair Camera Head Gimbal | Drone Accessories Kits | - AliExpress"
Now I would ask if you have viewed any YouTube videos on the disassemble and work on your Mini. Dealing with such delicate work is not for everyone...
Good Luck...
mnaake
