Return to Me
Bigpoppapump
I've tried several locations and both methods of telling the mavic to return to me after moving away from the original launch point. Today's failure, like all the others, said not enough gps signal. I had 15 satellites and 5 bars (max) of signal strength. I'm sure it's me but I'm dumbfounded as to why I fail.
Check out your flights log and see if they reveal what happened.
I haven't checked as to how the Mavic returns to "You" but two of my past drones used the controller signal to home in to , not GPS .
The DJI GO app uses the mobile device's GPS data when resetting the home point to the mobile device's current location.
Makes sense . Maybe I should keep GPS activated on my phone when I fly ,lol. I've never used the return to me function though .
What device are you using?
Is it a wifi/gps capable device? Or just wifi?
The drone records a "home" position when it takes off with it's own internal GPS, doesn't matter if your phone has GPS enabled or not
It can't record a gps for the return to me function as it would have no idea of where I would be when I wanted it to return to "ME".
Reactions: IADRN43
I think you should read the original message more carefully.
Sounds like an issue with your phone updating its gps data to the go app.
You dont have the gps turned off to save power or anything like that?
Bandar200718
