Risk Assessments
@AlanStockyard a simple risk assessment ,should contain at least the following items
(1) before you go to where you intend to fly ,check out the airspace for any TFR's or other permanent restrictions regarding that area to make sure its ok to fly there
(2)upon arrival at the site do a visual check to ensure you can undertake the flight safely,this includes any obstacles that could cause issues with GPS signals getting blocked the height of such obstacles ,and in the event that you need to make an emergency landing finding somewhere to achieve that
(3)check that the flight can be carried out within the guidelines of the category that you are flying under,
(4) check that the weather is suitable for the type of drone you will be flying ,and that the drone is in an airworthy condition to the best of your knowledge
(5) and finally if you cannot complete the flight safely ,for any reason ,then abort until you are satisfied that you can
Reactions: DougMcC and Carb63
lucent6408d
