RTH as controller - weak signal
Go 3 for the P3 (and before they split to the Go 4), at one time had a problem on Android in properly interpreting correct app GPS location. Looks like it is rearing its ugly head.
What does the app map show as your location without having powered on the AC? Back then it was off 2.5 miles WNW from actual location.
That's irrelevant and completely unrelated.
His app and Mavic are working properly.
His problem is that the app doesn't accept the GPS data from his tablet.
Not completely irrelevant. Both cases were/are device GPS problem in the app.
I was simply giving an old example.
The incident you are thinking of was due to a bad firmware release.
It had nothing to do with compass or GPS.
I also get the weak gps although obviously correct on the map. How about they just add an option to allow you to touch the point on the map that you want to set as home...
Or a do it anyway prompt like when you landing
Albrecht0803
