RTH
Roostertails
Kentucky
Quick question have read the manual twice maybe overlooked it. If I set the RTH on my Mini and take off and then later return to home, and fly again from that spot do I have to set home again. Also if I change batteries do I have to reset home from that spot? Thank you for your help.
It sets the home point itself on [every] take off. It shouldn't matter where you take off from.
Mediterranean by mod for clarity... see “[xxxxx]”
Every time you power down your drone it loses the recorded home point and every time you power up and it gets good GPS location data, it will record a new home point.
When you set an RTH height, that stays set but will be reset if you later update firmware.
bullet_magnet
