Thanks... it did not switch to sd card automatically so I changed it in the settings.If you insert a SD card the default should change to the SD card. Only time I know the default switches to memory is when drone is powered on without a card installed.
Paul C
The "regular" high quality images are saved to the drone (either internal memory or the drone's sd card). Thumbnail quality images are saved to the Smart Controller or phone/tablet device.
thanks... after I download... I cannot find them on the SC SD card (using a PC) ... either in the 8 GB memory or the 64 GB SD card. are they hidden files?The "regular" high quality images are saved to the drone (either internal memory or the drone's sd card). Thumbnail quality images are saved to the Smart Controller or phone/tablet device.
This bahavior of saving quality images canNOT be changed. It would probably take too much processing power and battery power to transmit each real photo to the SC or other device.
But you can manually copy them to the SC or other device. Use the "button" under the shutter button to start the process. Use care, while photos transfer reasonable fast, videos can take full MINUTES and steal power and time. You might want to wait till you land. But again, photos can be done in less time. Here's the steps:
THANKS... I found them...Frankly, it has been a while since I snooped around looking for them. I've been playing with the mavic mini lately.
I'd navigate all around trying to find them. I found some just now looking for older jpg's. I plugged the sc into my computer. I did not move the card to a reader on my computer.
This PC\rm500\SanDisk SD card\DJI\dji.go.v4\DJI Album
There's also some video in
This PC\rm500\SanDisk SD card\DJI\dji.go.v4\DJI_RECORD
Where the order above is MY computer, then the SC (aka rm500), then the Sandisk card, then the dji folder/directory/ then the Go folder and then either the album or Record.
Or they could be in SC internal memory:
This PC\rm500\Internal shared storage\DJI\dji.go.v4\DJI Album
