Screen Locked up?
sweetwater ll
Land Yacht
Presently in why, arizona
Only my second day on the mavic air 2, the winds the last two days have been 30-35 mph so waiting for today to take flight. Friday morning I was able to take off and land okay. This morning I wanted to fly some and get some experience. When I turned on both the cry and ma2 the screen asked to “connect” and I pressed that. Then the screen popped up a series of questions, “why did I get a drone etc”, the screen has locked up, the back button and the “next” can’t be seen unless I pull the screen down but the buttons won’ t initiate anything. Rebooted the iPad, still no good. what would you suggest?
Sounds like you had a few more steps to signing up and registering before flying ,
its likely that the screen did not freeze but was waiting for more input.
What I would do is reinstall the App : Carefully go thru those step, dont rely on the back buttons just try to get thru the Prompts . The back button will work once you get past those.
Phantomrain.org
Gear to fly your Mavic Air 2 in the Rain / Snow and land on Water
Somehow I got out of that and hope to never return! I find that there are some glitches to iron out, I’ve been taking off, then returning to land, turn off all then restart. Found that somehow it set a button to not go left or right in flight, ??? Got that turned off and now everything okay, albeit, temporary I am sure. It seems my learning curve is straight up!
aventux
