Screen recording error...
ff22
pacific northWET
Someone inquired about using the SC's microphone while doing a screen recording. I see an option in the General Settings to "cache sounds" but if I try screen recording I get an error shown in the attached image. I have both internal storage space and on the sd-card. Is there something I'm missing? And can you get sound recorded while doing whatever using the SC?
Usually on android devices it is not possible to record local video cache in GO4 AND screen record at the same time.
So if you had started screen record then start recording drone footage at the same time with video cache enabled, you'll get a message that recording video cache fails.
If you're recording with the drone with caching enabled and try to start screen recording that will also fail.
Reactions: ff22
Well, I don't think I was recording anything. The drone was sitting on my desktop. It was turned on so that I could get DJI-go working and play with its settings. But I understand what you are saying - film on the drone (no caching on controller) and then you can screen record. Thanks for the reply
Reactions: RogerMav
zotacreborn
