- Joined
- Feb 26, 2017
- Messages
- 17
- Reactions
- 3
- Age
- 70
Try to format the SD card.SD card error, check app. Help!
I believe at first you tried to format it via DJI Go 4 App (which one should be doing), by going into Camera Setting -> "Format SD Card". If that didn't work, try formatting via computer, the format should be FAT32.Did it, still error. How do I check it in the app?
I have now seen that a couple times, sometimes swapping the card will fix gimbal errors as well; who would have thunk?Thanks for your help. Swapped the sd card and error is gone
What do you mean by "swapped the sd card" ?
Mine is when recording videos and the gimbal wiggle a bit then the recording stops?? Should i change my 16gb lexar or reformat it on pc??I have now seen that a couple times, sometimes swapping the card will fix gimbal errors as well; who would have thunk?
Regards,
-d.
