- Joined
- Mar 28, 2019
- Messages
- 54
- Reactions
- 218
Followed a beaver on his way out after dropping clients off at a fishing lodge in Alaska. fyi- I'm not over it but behind and panned forward.
Hi. Yep, SE, an hour puddle jump flight South from Juneau.that's a really nice quick video...great job!
what part of Alaska? Looks like SE
I thought soHi. Yep, SE, an hour puddle jump flight South from Juneau.
That is brilliant to know. I spotted the one float lift and wondered if it was on purpose. So it was.That was nice and also good contrasting colours. I'm a pilot and have flown floats too and in your video it shows the typical float plane practice to get unstuck more quickly from the water. As you increase your speed and get your floats on step, you tilt your wings slightly to get onto just one float and then you lift off.
This gets you off the water more quickly than staying on both floats until you unstick, because floats tend to want to hold you on the water. Therefore, by lifting one float off the water, you have less areas to hold you onto the water, with just one float. You may not know this, but that is why you do that on water take offs.
Of course, on a runway/hard surface, you lift off both main wheels at the same time, since there is no stick factor to contend with, as when flying off floats.
Yes, it was on purpose and you will always see that if the water is relatively calm, with any well taught float plane pilot. The absolute worst conditions to get unstuck, is when the water is like glass. So, another little trick all good float plane pilots learn for that sort of condition, is to taxi out and do a large figure 8 on the water and then back taxi and turn and take off running through the figure 8 you just made.That is brilliant to know. I spotted the one float lift and wondered if it was on purpose. So it was.
